Anyoone using Bristol Babcock PLCs
backtoplc
May 2005
Hi ppl,
I might land a job where they are using Bristol babcock PLCs. I've never heard of them. I have been in the industry for only 2-3yrs.
Any of you guys using them?
any opinions?
thanks.
Theyre not so much of a PLC as an RTU/Flow Computer. Yes I have heard of them and bumped into a few but theyre pretty specialist, much like the Fisher ROC and Ferguson Beauregard RTU's.
They're used virtually exclusively in the Oil & Gas industry for well monitoring & control.
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
35
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
70
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
130
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
228
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
75
