AOI - change Local tag to Parameter?
harderga
Aug 2007
Ontario
Hi guys; I have a large AOI which was created with some Local Tags (UDT Structured) which should have been InOut Parameters. There are lots of references in the AOI to this Local Tag element. Is there a way to change this tag from Local to Parameter? Cannot simply create an Alias Parameter, as the Local tag is a UDT structure.
(Studio5000 v32)
Found it! On the Add-On Instruction from the Assets tree, open the Parameters and Local Tags dialog, and in the Usage column you can pull-down to change Local to InOut Parameter, etc.
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
22
346
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
172
I am very new to Modbus and the industry, so forgive me if I am missing something obvious. I have known Modbus register addresses coming from a...
235
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
139
I have an AOI with revision notes. Someone entered the last note into the description instead of the notes. I cannot just click into the revision...
152
