AOI - nesting... kinda
TheWaterboy
May 2006
-27.9679796,153.419016
1,927
I'm thinking of the MSG as an AOI just because I couldn't think of another example that would have the same prefix with different suffixes.. you will see what I mean.
I have an AOI for MSG diagnostics. Works fine but requires me to enter the
same tagname 4 times.
Is there a technique to only enter the prefix once and have the 4 suffixes .DN, .ER etc automatically created?
I think the way to minimize the coding would require you to actually use excel.
You can either decode the rung's neutral text,and replicate a bulk amount, or you can also export his routine as an XML.
Same goes for tag generation. Hope this can help! Another thing you might be able to do is create aliases for these message.er/dn/en bits, and use them without lookup required. Not sure if you want to go this route.
Regards,
-PreLC
I have still never exported to Excel and edited,. I gotta do that someday .
But... I was reading through the doc and it said there is a data type of "Module" for an I/O parameter... And that works! I don't recall that being an option before but maybe I justy never considered it. But it looks like it works just fine.
So were you able to put the msg tag as a parameter?
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
488
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
178
I am very new to Modbus and the industry, so forgive me if I am missing something obvious. I have known Modbus register addresses coming from a...
238
Does anyone know of an AOI using the user ASCII protocol select on the L6x controllers that will talk Modbus RTU using RS-485? Thanks, Trevor...
142
I have an AOI with revision notes. Someone entered the last note into the description instead of the notes. I cannot just click into the revision...
152
