Approaches to test PLC programs (need a urgent reply)
funfun66
Nov 2011
detmold
Hello,
I wanted to know what are various approaches to test PLC programs.
the one i found is
1) Virtual Commissioning
2) Simulation
3) Model Based testing
4) Model Checking
5) Analyzers.
6) Manual Testing.
but i hav not understood the difference between Commissioning and Simulation. as i think both of them revolve around each other. also can i get some more idea about model based testing
I read virtual commissioning to be a collection of individual simulations (plcs, drives, mechanics, images etc) linked together to form a complete system.
After you finished the "virtual commisioning", your customer will send you virtual money.
"Simulation" is when you are late for a deadline, and you fake disease to get your *** out of the hot water.
"Model Checking" ... sorry I forgot what the question was. There was a neat model passing by I had to check out.
This thread is analogous to a typical testing scenario. Wait to the last minute of a project and then enquire about testing. Wait close to a decade then wonder if it was even tested in the first place.
Hi, I am using M221 reading from 3 different sensors (modbus rs485) sharing same bus (daisy chain). I am currently using READ_VAR (in total...
99
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
204
See code at the bottom. Hi all. For the story, this is my first complete project using a Rockwell PLC, I've been mostly working with Unity Pro...
809
My question is regarding the number of Test outputs vs the number of inputs in a module. In the case of a 1734-IB8S card, there are 4 test...
1,230
Hi, I have to test a control logic that required to change the input temperature as the process variable from thermocouple transmitter on the...
636
