Archestra Graphic Disappeared (graphic editor opens empty)
phuz
Jun 2008
Mohnton, PA
1,044
Got myself into a bit of a jam this AM. Somehow the graphic editor hiccupped and when I went back into my graphic, everything was gone. I restarted the IDE, and even rebooted, but it's gone. Fortunately for now, the deployed object and InTouch app are unaffected because I haven't redeployed the InTouch app, but it does show pending changes.
I tried to upload runtime changes from it, but get this message: InTouchViewApp_001_004:Object is in pending update or software upgrade needed state.
Is there any way to recover this graphic? Can I locate that particular graphic on the deployed HMI and copy it back to the IDE somehow?
EDIT: In the deployed folder, I found the graphic .vedef file and when opening it in notepad, it contains all the things from that graphic; but is there a way to get this back into the galaxy?
I would contact support and see if they can assist you, but otherwise, try a right-click on the symbol or object and click "Validate". Validate is usually what resolves System Platform object or symbol issues for me.
Hey Guys, I have been creating Tank graphics in InTouch, but I also have Archestra system as well. I’m wanting to create an Archestra smart Tank...
1,049
Hi, I am having trouble with this fault that is occurring in a plant. Running ArchestrA 2012 V3.6. The problem is seemingly random. it causes...
1,521
I’m using the premade situational awareness input graphic for a few setpoints. It doesn’t populate an on screen keyboard when I click on it to...
2,018
I'm having issues getting the "while left/key down" or "while right/key down" triggers to work. I used the same script with the standard "left...
1,598
I'm aware that Wonderware can launch an application using the Startapp function, but is there a more specific way to run an application inside of...
1,948
