ArchestrA JupiterGraphic
DJShardy
May 2018
Melbourne
Hi, I am having trouble with this fault that is occurring in a plant. Running ArchestrA 2012 V3.6.
The problem is seemingly random. it causes Tags to not respond.
The following errors are displaced in SMC logs while this happens.
To fix this I just need to restart the ThinClient via ThinManager.
Googling suggested to me that it was a problem with windows possibly the AV. I don't think it is this.
Has anyone had similar problems?
Code:
Error: 'ArchestrA.Visualization.JupiterGraphic.JupiterGraphicContainer' failed for the following reason: 'System.ComponentModel.Win32Exception (0x80004005): Error creating window handle.
   at System.Windows.Forms.NativeWindow.CreateHandle(CreateParams cp)
   at System.Windows.Forms.Timer.TimerNativeWindow.EnsureHandle()
   at System.Windows.Forms.Timer.TimerNativeWindow.StartTimer(Int32 interval)
   at System.Windows.Forms.Timer.set_Enabled(Boolean value)
   at System.Windows.Forms.Timer.Start()
   at ArchestrA.Visualization.GraphicLibrary.aaEmbeddedSymbol.CheckAndStartOnShowScript()
   at ArchestrA.Visualization.GraphicLibrary.aaEmbeddedSymbol.OnShow(aaDataSubscriptionManager p_aaSubscriptionManager, Boolean runOnShowScript)
    at ArchestrA.Visualization.GraphicLibrary.aaGraphicContainer.OnShow(aaDataSubscriptionManager p_aaSubscriptionManager, Boolean runOnShowScript)'
Code:
 Calling ShowSymbols on Jupiter Graphic Manager for window 15803874 failed
There is approx 10 different window codes ( 15803874 etc etc )
So I made some changes to our plants WindowMaker application and I'm having trouble deploying the update to the live runtime. From the deployment...
141
Dear All, We are designing a solution with 1756-L74 and Archestra. We need to use SOE to show on HMI. Please mention any solution if someone did...
141
So I'm trying to enable history for a tag that is being used to display PPH on InTouch. I was able to locate the tagPath by finding the display...
707
Got myself into a bit of a jam this AM. Somehow the graphic editor hiccupped and when I went back into my graphic, everything was gone. I...
1,093
It's a while since I had used this that I forget where the setting to enable/disable object security is. There are some devices (pumps/valves)...
863
