Arduino to ControlLogix
Ian762
Aug 2013
Clearwater
31
Has anyone had any experience trying to connect an Arduino to ControlLogix? I am trying to use the Digi One IAP box to talk modbus to the arduino and then use a SLC typed read MSG to get the information into the PLC. I am sending the request from the PLC to the Digi One and the arduino is reciving it, however I am not getting any data from the arduino to the digi one to pass on to the PLC.
I have used this same ControlLogix/digi one setup to talk Modbus to other PLC's previously and thought it might be a good way to go since the Arduino can talk modbus/RTU.
I am working on an inexpensive solution to read data from an analog input to the XBee and transmit it back to a ControlLogix PLC.
Any thoughts or suggestions on this would be appreciated.
Ian
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
119
I am working on a project that had originally started on a sparkfun redboard artemis. Through some testing I've pushed to utilize a PLC for the...
1,595
Hello, I have been getting more and more requests for Real Time Clock (RTC) sensitive automation from my clients. I know that there is a Modbus...
2,750
https://www.arduino.cc/pro/software-plc-ide Diving in when I get home. With its full IEC language support, object-oriented programming...
65
19,709
https://www.hackster.io/news/arduino-unveils-the-opta-its-first-micro-plc-for-the-industrial-internet-of-things-d97f1d6b868a...
32
10,147
