Are you using the (free) Ignition Panel Edition?
surferb
Jun 2007
DC area
1,777
I think it's been about a year and a half since Inductive Automation started offering the Vision "panel" edition for free for small, single PC control systems without data logging. Are you using it? Are you using the free OPC-UA server for AB, Modbus, or Siemens - or a 3rd party driver?
Not actively using it, but did a quick trial for an in-house refurbishment project. Connection was to a contrologix processor over ethernet using the supplied OPC server.
The project got put on the backburner, but would definately take a closer look if it goes ahead in the future.
My father was using it in his plant for a while, but it didn't take long for him to upgrade to the Vision Limited. I just found out that he purchased the SQL Bridge last week. hahaha he is hooked now! Developing left and right! He even showed Tom C. (the president of the company) how to access the Ignition applications on his own desktop. Needless to say, Tom was very impressed and wanted to 'see' more (he only has view only right lol).
Ia
used/using it, loving it! made some real nice panels with it. It also really helps customers decide on getting the server version if needed. very functionl easy to use
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
38
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
77
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
134
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
243
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
79
