Array index within RSLogix 5000
Hi guys,
I have a question related same topic. But a little bit different.
I have 2 arrays. One of them is VALUES_TABLE [32,100] and real type. Another is COUNTER[32] and DINT type. Now, i want to use as VALUES_TABLE[0,COUNTER[0]]. But i'm getting verification error. Can someone explain how i can use an array element as index for another array?
You're right, it doesn't like it. The value of COUNTER[0] has to be copied to tag of DINT type and then used in the subscript.
MOV COUNTER[0] myDINT
MOV VALUES_TABLE[0, myDINT] myREAL
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
741
Sorry for the word salad title, I'm having trouble putting my problem into words. Basically I have two arrays of DINTs, both the same size...
29
7,983
Hi, Unity has the option to index its arrays between any two numbers; e.g. "ARRAY[13..27] OF INT". I am writing a DFB which needs to take in a...
2,388
I have a variable IDX that varies from 0-10, can I use the following: CONCAT ArrayStr[IDX] ArrayStr[5] Destination To write to a string...
1,481
I've got a rung that uses the first pass bit to initiate a For argument. In the Routine named 'Alarm' I have something like this...
10,001
