AS-I Safety Monitor
userxyz
May 2002
any
2,768
Me Again, but another problem:
We have 3 light curtains (emergency stops) on a machine. Curtain A, B and C.
There is a button, @ the site, when u push the button and hold it; then curtain B and C won't stop the machine. U can go in these zones.
And there is a Reset Button.
This is actually a question for persons who know how to program a Safety Monitor.
I've programmed the Curtains 2-Channel Forced.
And the Safe Slave with the button for B+C also 2-channel forced.
But here it comes: This Button has 2 contacts; AND I USED 2 CHANNEL FORCED.
We have some troubles, sometimes we need to reset the module, it goes in a fault (hardware fault); detected with diagnostics of the software.
2 Channel forced = 100ms synchronisation.
2 Channel Dependent = user defined synchronisation time
2 Channel Independent = nu sync.
Should I've been used 2 Channel Dependent and a Sync of 2s ?
Is that the possible fault?
It's the safe slave who flashes red in diagnostics; then we have to reset to let it function again.
Great thanks,
Combo
Good Afternoon , We have a number of MSR127 Safety Relays on various machines. We had an issue a few months ago that we had a EStop...
3,750
Can we monitor/watch the status of safety tags in SafetyTask rung? Or the status of safety tags are freezed? Thanks a lot.
1,624
Anyone know if a PLC output can be used to reset a safety monitor? I want to use an OIT, in addition to a local pushbutton, to turn a PLC output...
2,293
Trying to replace a bad Siemens ASi monitor. The replacement unit that I could buy has a password. Probably a used one. How can I get in to be...
1,827
Just a quick one ; i have a faulty siemens asi safety monitor 3RK1105-1BE04-0CA0 and want to replace it with a spare. i have the cable pack from...
4,533
