ASCII Data from Weigh Bin Scale with Quantum Unity Pro and 140 ESI 062 010 Card Help!
bmrinell
Apr 2014
Minnesota
Anyone have experience using Unity Pro function block MUX command words to read serial data? We are upgrading from an Allen Bradley PLC 5/40 to a Modicon Quantum Unity Pro 671 60 Processor and trying to read ASCII data from a Thermo Ramsey 10-150 with add on serial/ASCII module output card.
The data read works for awhile but then it will stop and the only way to get it to continue is to use hyperterminal and send a CTRL-R and Carriage Return back out the port to wake up the serial output to resume communications.
We are using 140 ESI 062 10 Port1 and Port2 to read 2 weigh bins.
2400 Baud, 7 data bits, ODD parity, 1 stop bit, keyboard off, XON/OFF disabled.
Anyone have any ideas or experience going from Allen Bradley PLC 5 to Modicon Quantum Unity doing serial?
Any help will be greatly appreciated. Feeling stressed.
BMR
Hello, Thanks in advance. How can I send more than 82 characters using AWA or AWT? to Zepra Printer via serial Rs232 communication? Normally I...
770
Does anyone know how to inhibit the 232 module from sending data during PLC power-up? To send data during normal operation, the Transmit Record...
1,907
I am working on a project, inside an AB CLX, I implemented the Modbus TCP Client AOI published on AB website, to interreact with a Modbus ASCII...
3,586
Hey working on a project where I need to send a String Command to a device in order for the device to perform an operation. It's over Profinet but...
1,874
Hello all, as you probably are all aware I have been trying to interface an A&D GX4002A balance to a 1769-L24ER-QBFC1B controller by the use of a...
1,486
