ASCII to ETHERNET /IP
JeffKiper
Jun 2006
Indiana
2,460
I have been using Real Time Automation for a long time. Does anyone have another recommendation for ASCII serial to Ethernet//IP?
We have a scale supplier that wants easy. I think RTA is probably the easiest, but I dont want to get suck in my ways and be the old timer that says " I've done it this way for 20 years". I just making sure I dont get passed by with something newer and easier for the field guys to handle.
RTA is actually old timer.
Many scale manufacturers have Ethernet/IP. As option.
If not , use socket and save yourself $$$
Plus ASCII is limited, where socket approach can offer flexibility like download different programs to the scale.
Yes the RTA is old school. The terminals that we are retrofitting are all in Classified areas the PLC is outside the area. Ethernet/IP isnt rated for C1D1 installs.
Any new install is Ethernet/IP.
Is the control system AB or another brand? I have used both Point I/O and Flex5000 serial modules to talk to random check-weighers, barcode scanners, and printers in production lines before. It's likely whichever brand you are using will have a decentralised 232 offering with their I/O adapters.
The controller is AB . I wont always be onsite for setup or testing. The scale guys will be setting these up in the future for these retrofits. Thats why Im leaning towards keeping the RTA because of ease of setup for them. They just have to make sure the plant guy has the PLC TAG exactly the same.
Good day! I am working on a project at our campus to integrate fleet vehicle chargers with load management so we don't overwhelm our service. The...
37
3,826
hi guys! I need to communicate a device with my 1756-L8, im confused about the class, instance and attribute i should use to send ASCII commands...
514
I need an adapter for Ethernet to RS485 ASCII traffic. I found a couple cheapos and bought them but all the docs were in Chinese and I just...
1,834
PLC is ControlLogix 1756-L73 CPU with firmware 28 In the PLC the value for A60[110] is "AT", Style ASCII, Data Type INT. In KEPServerEX I tried...
1,546
I have a SCL 500 5/03 the a ProSoft MVI46-GSC card. The ProSoft MVI46-GSC sends out ASCII strings to serial printer. Working fine for many years...
2,063
