Assistance with Modbus Serial to Ethernet IP
scantime
Apr 2014
US
25
Hello, we have been tasked with finding a solution to add Modbus devices to an Ethernet IP network. Is there anyone that has experience with a specific converter? I did a cursory search and found some interesting devices by Prosoft, but first-hand experience would be helpful.
Thanks!
Have a look at these modbus gateways:
http://www.moxa.com/product/MGate_MB3180_3280_3480.htm
I have used one of these before when communicating between a Schneider Premium PLC and a 3rd party irrigation controller. Someone else set it up though so not sure how easy that bit was, but it has been working reliably for a couple years now.
I've used one of their other general ethernet to serial converters and that was pretty straight forward to configure.
Anyone know of one that will repeat the serial connection? In other words I could plug the source device into one side, pull ethernet modbus out the middle and still repeat the serial connection to a PC for its original purpose.
You can do that with the Red Lion device, download the manual and check it out.
đź“š
I know you could do this with the digi when converting ab df1 to ethernet ip. I am sure you could do the same with modbus. just keep in mind that you cant poll tremendously fast with both masters.
I like the AnyBus modules. I am a ModBus N00B, but have gotten it to work more than once :).
The idea here is to provide for a brief rapid influx of message codes while preventing sequentially repeating the same message. i.e. if two...
23
685
Hi All, This is my first PowerFlex 755 drive setup and I am having an issue with when I start the drive it runs at my minimum speed 5Hz, but...
429
We're upgrading an old PLC-2 system programmed in ICOM. We have the files, the PLC logic is in a .LAD format. Does anyone have working...
424
I am a complete newbie to this stuff and wanted to try this out and was looking for any information on how I can complete this by Wednesday...
19
12,743
Hi everyone, Im not after someone to do my task, I'm just after some guidance or even pointed to some online resources I may use to learn more. I...
29
8,182
