Auto Logout to lower level user - FT View 11
yiftachh
Aug 2020
Israel
Hello, I am facing few problems with my FT VIEW 11 HMI (The PLC is SLC Connected via ethernet driver):
1. Is it possible auto logout to login to lower level or other user?
I would expect it to trigger a macro in Runtime Security but it does not
It is impossible to login from server so events also can't help
2. Is it possible to control communication update rate.
I use station system with SLC PLC and would like bit group to communicate than some register tables or make all faster
3. What is the best way to popup alarm screen each time new alarm arrives?
Thank you.
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
601
I have a FactoryTalk SE 9.00 application which monitors and controls a batch application in two rooms. When running at full capacity each room has...
734
Hello, I have developed a Factory Talk View SE application and do not have any users or logins enabled. The system is auto logging out after...
4,375
Ok guys I have worked with the Panelveiw plus, and they have it where you can have the logged in user, logged out after certain set of time after...
964
I will try to clarify this as well as I can here and can do my best to clarify further if needed. I have a plant where I have about 5 or 6 areas...
11,930
