Automatic Device Replacement for DeviceNet
Sirius12
Jan 2009
India
I am looking for some information on the Automatic device replacement(ADR) feature enabled on some DeviceNet slaves. One part of ADR is configuration recovery. If Configuration recovery is enabled the devicenet scanner can download the stored device configuration to the replaced node. Can somebody shed some light on what device configuration exactly means?
Suppose you had 5 variable frequency drives connected to a scanner with ADR enabled.
If set up correctly, and one of the drives failed, the ADR feature in the drive would automatically detect when a new drive was installed and download its parameters automatically.
The idea is to make replacing devices simpler and less prone to programming errors.
Thank you for the information folks. I have some more doubts though.
How does the scanner know what all is included in the device configuration .. is it something that it interprets from the eds file ?
When you work with an offline file, you will have access to the parameters (from the EDS file). You can configure the device offline and then when you go online you can download that offline configuration to the scanner as well as the device itself.
Or
Go online to the network and upload the current settings from the device. You can then make any necessary changes and then load that information into the scanner.
OG
Hello everyone, I was hoping someone with a lot of experience with Automatic Device Configuration would chime in with any of your thoughts on this...
1,852
Hi everyone, I was just wondering what your thoughts are on using Rockwell's Automatic Device Configuration. How has it worked for you? Have you...
1,960
Good Morning , Thanks so much for your help before. I had to replace some Powerflex 525's on this project because of faulty displays. (...
4,244
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
98
Hello everyone, I'm having trouble solving this one and was hoping someone could help. I have a AB CompactLogix L16ER PLC connected to a AB...
595
