Automation Direct CLICK DS Bits and expanding
geniusintraining
Jun 2005
SC
8,276
I have a project/program that I am recording a time stamp and its using DS1-DS6 and shifts this down every time there is another 'event' because the DS register is 4000 I have a good amount of data that I can store.... now my customer wants to add 2 more time stamps, this will give me 222 events that I can record before it starts to write over itself, I know there is a DD but that is small so can I expand the DS register? I thought I read once that you could create a register? but maybe that was with the BRX
The Click data tables are fixed. The BRX would definitely allow a lot more flexibility and could be customized.
In the Click, you might be able to consolidate the data into a format where you only needed two DS register per timestamp where you pack the data into two digits each for month, day, hour, minute, and second, store that as a DD, then copy (unpack) it back to two consecutive DS registers. But if the year is important or you need finer than 1 second resolution you might need another register per timestamp.
Thanks Paul, I think I will try and cut it down to less data and then expand that way, I am logging
Month
Week
Day
Hour
Min
Event duration
Maybe if I can figure out how to do a number of day 1-356 that would combine the month/week, but it still needs to look good on a spreadsheet
I am already using the PLUS so thats a good idea, I just dont know and will need to check if the data can be read buy the Cloud, I am using the PLUS for the MQTT option, with the older Click we had to use a gateway or a BRX as the interface
Thank you!
Hello Everyone, I have a project that I have been working with a customer on and need some help/ideas, its a large project but small parts, one...
17
5,918
Looking at using a Click Basic PLC with Ethernet on some counting applications to count objects entering a certain area and count objects exiting...
2,436
I'm thinking of upgrading a very old Sy/Max 100 to a Click, and am trying to do it as cheap as possible. Looking through Click options, I see...
3,523
Has anyone had any experience with the new analog CLICK PLC from Automation Direct ? The application I need it for only requires one analog...
7,309
Just got this.... AD is having an issue with the Click PLC, they are nice little PLC's but need watch it if you have one, it should be easy to...
4,779
