Automation Direct PLC's - Array Support?
skyfox
Nov 2006
CA
279
Does Automation Direct PLC's Support Array's?
I don't mean at Bit level where you can access a Register bit via it's bit address (V2000.0), but word level Array's where say you can have 10 Vregister addresses and have them refrence via an index in logic?
Possible to implement one?
Thanks.
Thanks Bernie & icky,
Sorry I should have mentiond It's a DL-06
I will check out the sample. Not sure if FIFO is going to solve my issue. I need to have an array of data and be able to Populate an HMI Display using an Index. Looks like Pointers might be the answer.
Thanks again to both of you.
Hello, I have an automation direct d2 262 plc and C-more HMI EA9T6CL-R. I need to prepare a program, scheduled to be performed on a future date. I...
142
Does AD have a line of PLC's that can perform like Guardlogix?
1,477
Hi, I am currently challenging in a new requirement on my new project. We have delivered a project long year ago using DL-250-1 PLC+ 8 point...
1,539
Does anyone know if it is possible to control an Automation Direct PLC (P3-550E) using an Allen Bradley Panelview HMI (2711P series)? I'm not...
1,764
Looking at using a Click Basic PLC with Ethernet on some counting applications to count objects entering a certain area and count objects exiting...
2,453
