Automation license manager could not connect to server
MSoltani
Feb 2010
IRAN
when iwant to open any simense softwear this message so the program will not open also whill i click on license manager by this alarm , it was not open . What can i do?
The Automation License Manager service was not running.
Make sure it's set to run automatically.
This happens time to time, you then just need to manualy start the service.
Start > Control Panel > Adminstrative Tools > Services
OR
Start > Run > enter: services.msc
In the Services Screen, look for Automation License Manager Service. Right click on it and select Start
Im trying to install a Siemens upgrade license using Automation License Manager v6.0. I clicked D: mistakedly, and now I can not find a way to...
64
Hi Has anyone experience within using Siemens Automation License manager as a license server? The case is I have a virtual environment with...
531
The plant I work in uses Rockwell software primarily. We serve licenses to users with Factory Talk Activation Manager using a server running...
1,609
Siemens automation license manager had a drop down box that displayed missing licenses etc I am dreaming- what happened to it and how to get it...
1,064
ALM - v4.0 + SP2 The license for Step 7 is located on a jump drive. When installing the jump drive, I see the file AX NF ZZ, with the .ekb file...
6,492
