B&R 7CP476.60-1 CAN bus test
aress124
May 2022
Wrocław
Hello.
How can I test the CAN query in CP476?
Can you choose to send for some random data? To be able to measure with an oscilloscope, is it a signal on the socket?
I have Automation Studio but I don't know how to go to to be able to give something on CAN.
Maybe there is some other way to communicate CAN?
Regards.
I have worked a tiny bit with the B&R 2003 PLC and the CP476 and CAN.
I am no expert in CAN, but if you configure a CAN device, then the CP476 shall send messages to query the device, even if the device does not exist.
I found this link, and there is even pictures of oscilloscope traces.
https://www.ti.com/lit/an/sloa101b/...tion protocol is,attempting to send a message.
I also have to comment that the 2003 PLC is totally obsolete. If you are setting up a new project, then the 2003 PLC might not be the most futureproof choice. Just saying...
Thank you for your response.
Do you know if connecting the device via CAN as in the picture is enough to activate this port?
In my case, it does not work, CAN does not transmit and I do not know if there is anything else to add or if my communication is damaged.
Please help me How to B&R 7CP476.60-1 upload program Backup and download which program should I use. Pvi transfer tool.? And how. Thank you
88
I have 2 7cp476 plcs. How can I copy one of them and install it somewhere else?
74
Hi, I have a B&R Cpu 7CP476.60-1...I need to upload its program and variable list. I am trying with PVI transfer tool and one USB to RS232 cable...
6,371
Machine was running normal, turned it off and it never came back on, we got a NO-BUS/CAN connection on our monitors, we noticed the ERR light on...
2,270
Hi I'm trying get communication with BR CPU 2003. I got PVMan software from BR to pull log book off the cpu to my pc. PVMan failed to get log...
2,105
