B & R ACOPOS 1090 error
Andy M
DEAR/SIR
that is correct 3 psc of capacitor i have removed and measure, ihave send you email the attactments of the picture and also with the LCR meter reading.
i have write there the all of information regarding this driver with the photo ,send by PDF file at this afternoon ,malaysia time about 12.30pm sir.
please reply sir if you get it my email .
thank you sir
Andy M
dear/sir
i have send to this adress(<[email protected]>) at this afternoon,
i am sorry if i send it ti wrong adress,because i have message from this adress ,that why i send to following adress email.
the file i send is about 9mb ,i cant send to plc forum its can support only 300kb.
so if that adress is wrong,please give me your email adress sir?
thank you
dear sir,
i have acopos 1090 servo drive but last night error light blinking, i change one spare drive m,y machine is running but this drive fault "booting problem". any body know my problem solution.please meil me if possible.([email protected]).
request
Dear sir
i want how to make reset to acopos 1090 because
the drive led orange
the drive give me motor temperature 0.0
memory act 7&8&9&10 not give me step value
Before everyone goes replacing capacitors in the drive, the Run light blinking green is a standard pattern for either input power not being turned on (so the drive only has 24V DC) or the enable input being false.
In other words, a blinking run light means you don't have a fault yet, but you will if you try to run the drive.
hello friends
i have aproblem with acopos 1090
the error 41031
junction temperature model
over temperature
junction temperature:119.094
Acopos 1090 :- Error no 7210
Hello Friends,
In Acopos 1090 the error 7210 is comming means, Voltage unstable.As checked the AC110 & AC122 module is ok.
If anyone one suggest to rectify this problem.
Dear all,i had same problem with green light blinking, i change the three 0.033uf caps.it starts working for 1-2 minutes, after it starts blinkig again.
There are some error codes, 4005 and 9002.
It really anoing me.
Thank you in advance
David
Same problem
David
Hello !
I am working on an acopos 1022 and I have the same problem like you, the caps are good, I have changed the optocoupler after the diode bridge, but no result...
Do you resolve your problem?
Thanks a lot!
Hello All...good day...really need help here...We got acopos 1090 behaving like really faulty. During power-up the ready and run led were...
1,587
Our newish spray booth has the reciprocating arm driven by an acopos 1090 drive. HMI declares "reciprocating drive alarm" this happens several...
1,221
is there is any error list code for both acopos drives , i got the same errors at both with out any description , the errors number is 15206 ...
1,513
hay its me again the red LED on the drive is flashing it flashes five times then pause for a few second and it keeps on repeating that, can anyone...
2,216
Hello, I'm trying to test Acopos multi using Automation Studio. Ready LED is green blinking, how can i know what error of Acopos on Automation...
133
