B & R ACOPOS 1090 error
All the errors are described in the Automation Studio help. Error 9002 is heatsink temperature sensor not connected or damaged.
EDIT: Just download the trial version of automation studio, it will include their complete help file. Every error number has a little write-up about what causes it and possible fixes. Your PLC program probably also has a screen that displays the error text built into the PLC program automatically that would tell you what these error numbers mean.
Hi all,
Did you solve this problem?
I have a Acopos 1180, and it get error 7210, 7215. I tried to replace new 3 3nf capacitors but errors still happen.
Thank you.
I'm sorry.I not good english.
Used B&R Automation Studio communication with Acopos 1090 find >>>>
error code:7210 DC Bus:Charging :Voltage unstable
You can change Capacitor value 0.033uF/275Vac.
Acopos 1090 connect 3 phase input.
Email:[email protected]
show.php
Hi, Could you please tell me how to read error code of Acopos in Automation Studio, Thanks you.
9030: Junction temperature model: Overtemperature - Movement stopped
LA solution s'il vous plait​
Hello All...good day...really need help here...We got acopos 1090 behaving like really faulty. During power-up the ready and run led were...
1,587
Our newish spray booth has the reciprocating arm driven by an acopos 1090 drive. HMI declares "reciprocating drive alarm" this happens several...
1,221
is there is any error list code for both acopos drives , i got the same errors at both with out any description , the errors number is 15206 ...
1,513
hay its me again the red LED on the drive is flashing it flashes five times then pause for a few second and it keeps on repeating that, can anyone...
2,216
Hello, I'm trying to test Acopos multi using Automation Studio. Ready LED is green blinking, how can i know what error of Acopos on Automation...
133
