B&R Compact PLC
Hi, the software run under DOS only. I didn't manage to connect the PLC to the software. I repaired the PLC but the test has been made by customer at the site.
Good luck
Is it possible to get the LED Status Lights out of the code? I will use the GSV Block with the 'Module' Class and 'LedStatus' for the CPU. I am...
590
Been seeing a high failure rate on these PLC's on 2 of our process. The control power is feed through a APC UPS to a 24VDC power supply to power...
4,039
Has anyone ever used a 2711R -T7T Panelview 800 with a Compact Logix PLC over Ethernet comms? the 2711R -T7T Panelview 800 is usually programmed...
3,957
Hi I'm currently doing a college course in robotics and automation and a question we were asked was. A software application used by production...
3,662
Hi All, I was trying to do some searches within an offline program today and some tags i search for comes back in the search menu, "language...
2,024
