B&R cp 474
What version of Automation Studio do you have? The easiest way to do this with a non-Windows HMI is to setup the OPC server and tags on the B&R side and then it's just a regular OPC connection on whatever HMI you use.
If you make a Windows based HMI, B&R has a free .Net API that you can use which is super easy and a training manual that explains it all (TM712, google it and you'll find it). For a long time, you didn't even need to change the B&R project to be able to read and write to process variables with the API, might still be true.
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
41
Hello Guys I have a new task in the job. I have to upload the code from a B&R CP474, but for what i was reading in the forum it isn´t an easy...
2,317
Hello everyone! I was wondering if you could help me with something i'm trying to do solve. The situation: there are an old machine with stepper...
4,140
Hi there, I am trying to make a running spare part of a B&R CP474.I am using PVI,and need some help.First,I explain my steps,that I have done...
2,324
hello every one: I have buy new B&R cp474 plc, and I need to make it as spare part of original one, so I do like this by useing PVI tool: 1)...
1,501
