B&R IPC5000, PLC 2005 and ACOPOS1022 servo
goghie
Jan 2008
Belgrade
800
My clients have this 16 year old, but quite good machine with B&R IPC5000, PLC 2005, ACOPOS1022 servos and some Lenze 8200 VFDs.
Due to Lenze VFD fail (which I replaced with same model), I need to access to application and check some CAN settings and I would like also to backup everything.
I've downloaded Automation Studio 4 and Servosoft and obtained test licences, but mentioned equipment is not supported (I presume because it is old).
What software do I need in order to do it?
Can I upload application from the equipment with regular Ethernet cable or do I need some special interface?
Thanks in advance.
I've worked with the 2005 CPU and 1022 and 1045 drives, using Automation studio 4 (years ago, can't remember the minor version).
I'm pretty sure with B&R 2005 there is no upload. You must have the source code.
Never used IPC5000.
Thank you very much for info. I will try to make image of IPC's HDD and to decompile it.
BTW, I'm surprised how hard is to find B&R experts and although there are trial licences available and some knowledge base online, I'm shocked that I could not find exact name and version of software needed for programming the mentioned equipment in documentation.
I spun up an old VM, hope this helps and sorry for the confusion earlier saying it was V4 (10 years since I worked on them).
Hey Guys i was just after a bit of advice and was hoping some of the longer serving automation gurus might be able to help me out. We have just...
1,565
Has anyone any info on this panel. A bit ancient by today,s stuff. I would like a manual or info if anyone has any experience of the devive.
3,028
Hi, I am trying to set up a plc. I've never done any programming with ladder logic previously. I'm trying to set up a a program to turn a device...
115
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
52
30
