Bailey Infi 90 DCS - Rockwell gateway ?
EICS
Dec 2008
Melbourne, Australia
323
has anyone known of a gateway to bridge between a Bailey Infi 90 DCS and a Rockwell Control Logix 1756-L83 CPU successfully?
i believe there is a product called a GPI (General Purpose interface) or HGS (Harmony Gateway Solution) to bridge the 2 devices via some kind of point table in the device?
My Bailey Infi 90 DCS has the following if it helps
- 2 Only BRC300 CPU's in redundant pair mode
- 3 Only CIU01's ( Infi-net to Serial for EWS and Scada servers)
- NPM's etc
i want to set up a bridge to communicate between and existing DCS and 3 or more New Rockwell 1756CPU's.
i am located in Australia and hoping someone in USA has known if this has been done successfully.
any info on protocols etc is handy.
I did a bunch of research into similar stuff before, so take it with a huge grain of salt.
As far as I know, there's no direct bridge you can get, the best you can do and this is probably what they are selling you is a modbus bridge to Infin 90 then modbus over to Ethernet/IP.
I also know people have used Rovisys OPC to 90 then Kepware OPC to AB then bridge the two.
I have Bailey infi 90 DCS system The composer (EWS) was unable to establish communication with ICI . I got this error message anyone has any...
480
Never thought i'd work with something this old!!! Can anyone help in sending me a basic cascade PID flow diagram for a bailey's system controlling...
2,247
Does anyone have any experience with Bailey Infi90? Having all kinds of trouble with our system. Replaced a bunch of i/o modules that were bad...
4,391
I operate a distillation column for Argon gas. It has a pressure controlling valve that cools a condenser at the top of the column with nitrogen...
2,277
i have a citect server to upgrade from WIN XP. does anyone know if the Citect Bailey Driver has compatibility with Win 7?
1,662
