Valve control question using Bailey and Wonderware
supertrucker
Oct 2016
Oklahoma
I operate a distillation column for Argon gas. It has a pressure controlling valve that cools a condenser at the top of the column with nitrogen gas. This valve controls the pressure on the column. The valve swings open and closed too fast and too far in my opinion and it is causing bad readings on the argon gas in the column because the increase in pressure and cooling makes the nitrogen remain in the column instead of venting. I am a complete noob. I know there adjustments that can be made, but what would be the typical change to fix a problem like this?
I hear ya. Unfortunately most things we are left to figure out ourselves. Its pretty sad.
I would hire an outside integrator. In my area it's a $ 105/hr. They come in and do specialized work for us. It's a great deal in my opinion. They only come in a few times a year. What you describe is a couple hours of getting familiar with the process then about an hour to tune the PID loop.
I wouldn't touch it with a ten foot stick unless I was 95% sure I knew was doing. Your process sounds pretty unforgiving.
What type of valve is it? What type of actuator?
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
423
So I'm pretty green when it comes to troubleshooting in the field so bear with me. We have a Danfoss valve that opens/closes from an analog output...
23
968
Hi there, We have a system at a water treatment plant where large raw water tanks feed into the plant that's all on the same level. At high tank...
18
3,774
Working on a site where they are using a DeltaV DCS system. They are using Topworx DVC6200 controllers on their modulating valves. These control...
1,072
Does anyone have any experience in this? I have a lead lag pump setup for water that is maintained by pressure using VFDS, the idea is to have...
1,840
