Basic home-use PLC?
Snikrep
Guest
S
I programmed a 90-30 PLC a couple years ago so I'm not a newbie when it comes to PLC's... it was just a gig during high school so it's not my life, but I remember how handy they were for certain things.
I noticed in my in-laws house a old setup they have for a heating damper control. It's a couple of relays that flicker on and off depending on the thermostats.
A tiny little PLC would replace them pretty nicely and make everything look a lot slicker, but looking around it doesn't seem there are very many cheap little packages to buy? I saw the Unitronics and then the other main one (something -05, can't remember the rest of it) - I'm looking for something that's even cheaper though.
I just didn't know if there are any cheap consumer level ones that are in the sub-$100 range for this or Christmas light customizing? They're so handy and the technology is so simple, I thought they would be a commodity by now.
eBay my best bet for a older 90-micro?
Thanks for the link, those things should be a LOT cheaper but I guess there's not a market for this sort of stuff. Not too bad though.
Ah well, I remember having so much fun with ladder logic that I was kind of trying to look for an excuse to play around with one - LOL, I'm an engineer so perhaps I try to overcomplicate things.
Have you looked at the Allen-Bradley PICO controllers? You can download the programming software free, or just program it with the keypad LCD/display. You can even get some models that have expansion I/O and will display triggered messages on the LCD. I have one of the small ones: AC power, 8 AC in, 4-isolated relay out running my well pump/filtration system at home. Ask your AB rep if he can get you one to try out thru the "one-stop sample shop" and they will give it to you free!
Hello All, I am stumped on how to convert a %MW to a %MF using Machine Expert Basic and a Modicon M221. The help files show a word to a double...
41
Hi all, I have a noob question regarding data handling from sensors. I understand configurations and I/O mapping sensor input/output variables...
227
Hello I am new here and new to PLC's, I wrote this program for a class that I am taking and my local tech school. The description is switch 7 will...
423
1,999
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,095
