Basic Question: How do I stop SoftLogix from running all the time?
brstilson
Jul 2012
Michigan
246
I installed softlogix but only to use as an simulator once in a while. However it seems to insist on running in the background all the time. I can't find any settings where to change this. Any tips?
I only know enough to be dangerous here, but I have a SoftLogix5800 engine running on my box. I'll assume you have the same.
If running XP on your box, go to Start/All Programs/Administrative Tools and select Services. From there, scroll down until you find the SoftLogix5800 Slot 1 service (your slot number may be different, depending on where your soft PLC resides in the virtual chassis). If the service is set to start up automatically, try changing Startup Type to Manual. I believe this will do what you want.
Hi all, I have a noob question regarding data handling from sensors. I understand configurations and I/O mapping sensor input/output variables...
227
GE 90-30 using ME 6.0 - Newbie question... Let's say on rung 10 I set a coil (S) with a one-shot. Input to coil drops out, but coil stays...
30
11,191
Dear experts, i have pretty basic/ dump question, can someone help me to figure out how to read/ what is this? i assume it is solenoid vavle...
1,064
Create ladder logic program to count 4 on pulses (not using a counter) and then turn the output on if the on pulse input signal can look like the...
105
36,696
Im looking to hook up a 3 wire PNP photocell to an Allen Bradley 1746IV 16 module. Ive watched videos about hooking up DC sensors, but they show...
2,995
