Basic Tube Mill Speed / Cut Off
protocolpacket said:
Hi 69FIREBIRD
Haven seen in any of your post the most important question raised by Peter for your requirement:
Regards
The requirements are good to know. They must not be too hard to meet given 69FireBird is willing to attempt this with a PLC. However, the time it takes to implement a flying shear or cutoff in a PLC can more than offset the extra cost of a motion controller no matter what the requirements are. There are basic requirements that must be met. I think these requirements tend to be underestimated. Then there is the support issues. PLCs don't have real time graphs and event logs that work at the millisecond or sub millisecond level. PLCs also don't ramp up or down using nice 5th order polynomials with a ton of math.
If you are interested flying shears and some shameless propaganda see:
http://forums.mrplc.com/index.php?showtopic=14908
If that isn't enough then see:
http://groups.google.com/group/sci.engr.control/browse_frm/thread/2573937888a724fd#
Edit. I just saw 69FireBird's post. 2 mm. That will be a challenge.
The general consensus here is to use a motion controller, is a wise choice considering your accuracy etc.
The below are a supplier of the Delta Motion Controllers in our neck of the woods, there may be others.
http://www.ecs.net.nz/m14.asp?Page=/Motion/prods/motion/field/index.htm
Is worth a look I think, we have a project coming up where we are using them also, going to be a learning curve, but with the right tools, should be an enjoyable one.
Hi all, I have a noob question regarding data handling from sensors. I understand configurations and I/O mapping sensor input/output variables...
221
Hello I am new here and new to PLC's, I wrote this program for a class that I am taking and my local tech school. The description is switch 7 will...
415
1,976
I’m a bit stuck on HMI (KTP-1200) programming… See the picture attached. The PASS or FAIL box should only appear when the toggle switch is...
1,074
Hey Programmers, Heres todays puzzle I was trying to solve... I have a Modbus TCP network with two Modicon M221 controllers live on my work bench...
469
