Baud rate control??????
marsu1821
Apr 2005
In a RS232 - RS485 converter cable for PLC of Siemens, there is a baud rate control.
Anybody can explain me the baud rate control useful please?
Thank you for advance
Do you mean the switch on the PC adapter (19.2 / 38.4)?
It's just there to tell the RS-232 side what communications baud rate to expect from the PC. 38.4 is faster than 19.2, but with some computers (especially older ones) 38.4 might be unreliable.
Hi, I have an RS232 string which will be constantly printed as fast as possible, the string is constructed as XX.XX<CR><LF> an example is...
3,542
I get the error "Error changing baud rate." for a QPICTAE0000 using the Tool Port.
1,299
I have a CNC router that employs a WIN7 PC to run the router software connected to a Compact 984-145 controller via modbus and an ethernet...
1,625
Happy Friday everyone, Disclamer: This is my first experience with a PanelMate In the User Guide for the PanelMate the screen shot shows that...
2,080
Need some clarification regarding the devicenet set up PLC is CLX with 1756-DNB scanner, trunkline using kwiklink flat cable with the micro...
5,148
