Hi
I have come across more issues with a baumer verisens camera when trying to input a code into the unit to verify.
Has anyone worked with the baumer verisens vision with tia ?
I have a string of [12] max that gets moved into the QB53 but I can’t see it on the vision software in inputs , I’m looking at the handshake and not sure if I have to send a parameter handshake but bit 0 to the vision to tell it to see a change how does the handshake bits work on parameters and results data getting and sending the qr code value
I’m think with the output (QB50) I need to trigger bit 0 to say I’ve sent the code and get bit4 to say it changed
Then there is inputs back to confirm this on bit 0/1/4
But I would like to know if this is right from some that has done this before
Thanks stu
Thanks stu
