BCD conversion error
Annie
Sep 2005
madras
22
I recently added a BCD to int conversion block to compare 2 MW.
The CPU has a SF error.In the diagnostic area it shows BCD conversion error.
I deleted the conversion block but still the error has not gone.
THere r other BCD conversion block also in the program.But didnt face this problem before.THe data is written from a DW which is word type.
Is there any way to know which block is having problem.
the cpu i am using is CPU 315-2dp.
Regards
Annie
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
119
Hello to all, Yesterday the production line stoped and since then we have SF light on the PLC (S7 315-2DP). Here is the screen shoot of the...
6,553
Hi. I’m doing a PV 1400e to PVP 7 migration and I don’t know how to convert the old 8digit BCD type from PB1400e into something that will work on...
593
Hi there. I have a Micrologix 1100, I have 6 switches to I:0/0 through I:0/5. My plan is to use I:0/0 to I:0/3 as set for a value of 0-15. I:0/4...
1,749
Hi all, I am quite new to PLC programming, so pardon my noob-ness. First, I have counters & timers in my program that I use to calculate total...
3,547
