8 digit BCD to 4 digit BCD conversion
Mikemator
Jul 2013
Durban
36
Hi.
I’m doing a PV 1400e to PVP 7 migration and I don’t know how to convert the old 8digit BCD type from PB1400e into something that will work on a pvp 7. I’m using an slc5/05 plc.
Any help would be greatly appreciated thank you.
If you have access to a 32 bit windows OS like Win XP 32 bit then the PB1400 application should be able to be imported into FTV. Then you can save it as the APA file for opening in the 64bit for any more configuration needed.
Hi JTCat, I have the converted FTV program running already, just haven’t decided how or what to replace the old 8 digit BCD with in FTV.
FTV doesn’t support 8digit BCD only 3 digit BCD or 4 digit BCD.
Looking for a source for a 2 digit display that can take BCD input for each digit. I have seen one on a machine but haven't been able to source...
5,122
I am trying to replace a Nematron 110 with a 550 Panelview. The SLC has a Single Axis Controller in it that is using BCD. I understand how BCD...
4,157
Good morning all, I'm integerating a device with a Rockwell PLC with V34 Studio 5000. The device reports error codes using a single integer to...
19
1,293
Referencing KB document QA9877: "...FactoryTalk View SE Graphics supports single precision floating point values, and by default only provides...
1,794
I am attempting to replace a single digit in string in studio 5000. I need to take the 23rd digit and change it from a 1 to a 5 while the rest of...
1,553
