Beckhoff Analog input card selection
Nov 2011
Ireland
182
i have a 0....20mA that represent -100.....+100watts
what card can i use to measure this signal
i have a KL3012. however i noticed that this is a different input and also that is has no power contacts
can this card be used
How would I connect a 5K potentiometer to a beckhoff analog input card EL 3061 (http://www.beckhoff.ca/english.asp?ethercat/el4031.htm) and 24VDC...
4,880
hi . we are using beckhoff decentralised I/O module on profibus , which has its different analog cards for RTD , current and Voltage input. i need...
5,909
Hello, I would like to control the valve through the beckhoff PLC. The valve operating range is from 0-10 volts and i have terminal EK 1100...
6,041
Hi. I try to understand how to read an analog input (4-20mA). Using TwinCAT. I found this example on how to scale the input into engineering...
2,985
Hi, I am facing a problem. I have configured the analog output terminal EL4004 as (output_1 AT%QW2: INT) but I did not get the output which I...
3,104
