Beckhoff I/O with Siemens TI 545
godfrey
Apr 2002
Charlotte, NC
412
I need to interface some Beckhoff remote I/O racks with a TI 545. How have you done it? I am thinking of Ethernet via a Beckhoff 9100 TCP/IP comm. module to the Ethernet card in the main PLC rack, a CTI model 2572A. Has anyone done this over Profibus? Thanks.
Hello godfrey
I used Wago remote I/O connected to CTI 2500-C400 plc using profibus.
So Beckhoff should be possible to.
You can only a maximum nummer of 16 slots(limitation of TI) for one DP adress.
Regards
Henny
Godfrey,
I've used Wago hardware over Profibus on the TI555 and it has been a good experience. I've also done Industrial Control Links hardware using Modbus/TCP into the 2572A; this also has worked well.
My preference of the two was using Profibus.
Tom
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
101
The system of position control is quite different in Beckhoff compared to Siemens. In a Beckhoff controller with Beckhoff drives on Ethercat, the...
856
Hello ! :) Struggling here with choice of technology for a big project. background: we have always used SIEMENS but after recent hiccups some...
2,573
Hi all, First time posting here. I have a Siemens Simatic S7-1200 controller that I intend to use for a small project at home. I also have a...
2,034
Dose anyone have experience with Beckhoff FC3121 profibus master PCIe card connected to Siemens CP342-5 as a profibus slave? The data retrieved...
17
4,813
