Beckhoff PLC help, startup does not complete
DonCollins
Oct 2020
Ohio
Any help for a Beckhoff PLC that does not start up correctly the first time? The system will lock up, stop responding at times, requiring me to cycle the power. The PLC does not start on the first try. The windows status bar progresses to different spots and just stops. It usually takes aroun 5-15 tries for the PLC to fully load.
My advice is to check the events log on the Windows administrative tools. This will give you valuable information to help you analyse your problem.
Thank you. No one is a fan of this Beckhiff PLC, and I tend to forget, it’s windows based. So I have never considered checking event viewer. Thanks for the tip.
Or just contact your local Beckhoff tech support. You will be surprised how much will they go out of their way to help you solve the problem.
I have a Beckhoff CP6202 IPC connected to a Beckhoff remote rack via Ethercat. I believe iPC is the PLC master and communicates with the remote...
3,624
I download Twincat software (trial vesion) of Beckhoff. But I can not find contents of 'Help' at this software. Any body help me?
5,606
47
Hello, We are currently working on a project that involves connecting a linear potentiometer to our Beckhoff PLC. After researching, we...
199
Morning all, we have a CP2715-0010 1.46GHz Atom running Windows 10 Enterprise (Embedded PLC with the HMI). Problem being is the performance is...
639
