Beckhoff target port not found error
acansoy
May 2016
adana
Hi all, I am trying to send e-mail with CX8090. I downloaded sample example from here https://infosys.beckhoff.com/english.php?content=../content/1033/tcsmssmtpsrv/html/TcSmtpSrv_FB_SmtpFull.htm&id= and set the input parameter according to mine.
But when I executed the function block, got the error Id:6, it means target port not found. After that I tried to change port number in config file as 587 instead of 0 which the default value and it goes 25 as I read in documentation but I got same error. So I stuck now, can not understand the problem, appreciate for any help.
I has an industrial pc connect to the controller. And write the PLC program to control the machine On and off in the industrial PC. It is work...
24,335
Hi, I'm working on a project that involves using the Beckhoff C6015-0010 running Windows Compact Embedded 7. Essentially, I'm trying to use the...
14,385
78
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,057
Hello sameone have Beckhoff PLC Siemens Sinamics V90 configuration example?
104
