Beginner programming
jasonnunn
Dec 2014
georgia
Hello,
I am new to plc programming and I have been tasked with completing a work order that Im sure would be simple for a seasoned programmer and I need some assistance. I have two control valves for two different tanks. I need to reprogram these valves to have only one valve open at a time. In other words, when one valve is open the other has to be closed. Both valves are normally open contacts. Can anyone help with this?
your "work order" sounds like school assignment to me...
but anyway, some of the questions that arise...
- what PLC system do you use ? (hard/software)
- you need to reprogram, what does the original program do ?
- why/when should one valve or the other be open/closed?
grtz
How do you code it to when you push a button attached to X001, it turns on Y001. Then, the next time you push the button attached to X001 it...
1,631
I have 2 CompactLogix 1769-L32E controllers. Each one has the following modules: Slot 1: 1769-IA16 AC Digital Input Slot 2: 1769-IQ16 DC Digital...
4,155
I'm new to the PLC world. I have a Automation direct system with a DL205 base and 250-1 CPU. I've read through the tutorial (PLC.net) and the...
6,962
J
4,893
