herman_swartz
Hello,
I have Fanuc 90-30 with cpu-331 and ic693acc300c switch input test module and ic693mdl740c 12/24 output control module. Entered simple -||-----( )---- ladder program. The contact is %I00001 and the coil is %Q00001. Program compiles and loads to the PLC ok. I am using VersaPro v1.5.
Several months back I tried doing the first program as above and found out the firmware needed to be upgraded. I bought firmware upgrade and installed upgrade.
The switch contact and coil contact color is red. I thought this meant both were active (1). The output contact is switching a light bulb, or should I say it should switching the light bulb but is not.
The bulb doesn't light when the PLC is taken out of RUN state and told to make all outputs high.
I must be missing something real simple.......
Herman
Herman
