Beijers E1000 - FTP Connection over PPP
Philg
Jul 2006
Adelaide
Is anyone aware of whether you can access the FTP data (trend backup data) through the PPP connection ?
I connect using the PPP connection, and then when using HMI Tools FTP Client Software with comms setup for the PPP IP address but HMI Tools software hangs when I try to connect.
The User Account at the HMI end has got FTP Read/write access.
Any ideas ??
Do you have a lot of large trend files in the HMI? If that is the case you could try to increase the time-out in the HMI Tools FTP client to the maximum.
You can also test with some other FTP-clients and see if they work better.
//Supporter
Sorry - my Firewall was causing the hastles and stopping my connection, unfortunately HMI Tools FTP Client hasn't got a timeout setting though as now my next problem is it only partially uploads the data in the backup files across the FTP connection when using PPP ...
I think the other FTP-client will have to be the way... have you used any that you recommend ? ... thanks
I have tried a number of FTP-Clients and the same problem as in my last post occurs.
It seems that the maximum file size that I can get across the FTP connection through PPP is 16384bytes at which point the data port is closed and the FTP client believes the transfer was successful (the file I am trying to extract is 341K so it is no where near completed!!)
Do you know if their is a limit? The files transfer fine when FTP over a TCP connection.
Hello, Does anyone have any experience of using a small label printer with a Beijers E1000 Series HMI. I haven't decided on a particular model of...
4,221
I currently have a E1101 talking across Modbus to a DSE 5220 Genset Controller using the following driver… Com1 – modicon Master/Modbus Naster...
6,986
I am trying to set up a E1101 to be a Modbus master to a Deep Sea Electronics 5220 controller. The DSE5220 has a RS485 connection. At the moment...
6,482
I am using an E1101 Beijers HMI touch screen HMI/GUI in conjunction with an FX3 PLC. The E-Designer software is version 7. The Alarms screen 990...
4,366
I have two Trend graphs but only want to back one of them up to the Compact Flash card. Under "System Settings\Commands" according to the manual...
4,341
