Beijers/ Mitsubishi backlights
jbt
Dec 2002
manchester
Hi
I am after replacement backlights for a couple of Mitsubishi / Beijers HMI's
or part numbers, source etc
I currently have the following panels needing backlights,
An E700/710
E900 Touch screen,
E1060
E150
also does anyone have any hardware manuals/schematics for this range of hmis
www.beijerelectronics.com / Support / Online Support / Operator Systems / Exter/E1000 / in right hand pane Manuals / EXTER Operator Panels Service and Maintenance Manual (MAEN757C)
Has all the part numbers.
For the older HMIs I might be able to dig through my backup files.
I have a number of old E series (900, 700, 300) I also may have a 1060 LCD screen complete with back light, by the way very often the almost none existent back light on the E900 is just the foil "reflector" coiled around the tube just remove it & it gives enough light.
I will see if they are still in my cupboard don't know how you could collect them though, let me find them first, if you send me a private message maybe we can sort something out.
I have some old project on Beijers E615 panel, do you know how I can see recipes? I'm unable to locate it in a project, am I missing something? I...
1,901
Hi I have a MAC10 terminal which I need to program for non-commercail use. I understand that the SC06CN interface (the one with the 5v power...
2,507
I am using an E1101 Beijers HMI touch screen HMI/GUI in conjunction with an FX3 PLC. The E-Designer software is version 7. The Alarms screen 990...
4,364
I have a client with an E600 terminal in a system which I supplied to them in 2006. The E600 has now failed. I still have the E Designer .MPA file...
4,765
I am trying to convert a Beijers MAC 50 HMI application to a new GOT application but the older system uses the Time channels function and I cannot...
1,143
