Best PLC & Advanced Networking Training
iadapt
May 2012
Indiana
177
Just wondering where you guys think the best place to get training is?
Considering, DCS, Networking, PLC Programming - Micrologix 500/5000 Contrologix, DeviceNet, Hardware, etc.....
- College
- Employers
- Seminars/Boot Camps
etc.
I'm looking for suggestions for advanced hands on training. Any ideas
Paul
http://www.ronbeaufort.com/
Give Ron a call to see if he can help out with anything, he's a valued member here
Second that.
Ideally, you'd want two things:
* A facility that actually has the hardware systems you use, all set up to experiement with.
and
* An instructor who is at the EXPERT level, in as much as actually using the system to solve real problems.
Miss either one of those, and you miss the whole thing.
Icing on the cake, of course, is when the instructor knows something of your particular industry, business, or process.
Hello all,
Believe it or not I have a job as a PLC Programmer (entry level) however I am just discovering the many facets, instruments, protocols and systems, there is more than trees in a forest. Its literally mind boggling! SO I am just curious as to the learning and career path that is (it appears) wide open to me.
I am seriously considering my next move in the learning curve. Lots of exciting opportunity. This site has proven itself HIGHLY valuable so I will be investing asap.
Thanks everyone!
Paul G
and go! I'll start. Always comment the Boolean instruction for their TRUE state. For example. It is much easier to read a normally closed contact...
65
21,580
Good Evening . I visited a pump station sight today that has a PLC-5/11 CPU. I was given a CD with only a file with a program and extension of...
3,778
Hi there PLC aficionados, I have a quick question for you. Do you use Linux in your integrator/automation engineer/Technician role? If, yes which...
20
8,343
Any manufacture recommendation for remote I/O for Siemens PLC.
2,926
We have an AB system that is connected to several CANbus networks via HMS gateways. A CAN message is comprised of upto eight, eight-bit bytes...
1,416
