Best practice for connecting PLC's to MES
I have not done that migration - Wizcon to Citect and a couple of others - complete re-write. Have you considered updating Citect? More and more in it with every new release - it is pretty good. Some things I do not like but mostly positive. And the Excel add in is pretty good for doing your databases.
Hi Bob,
yes short term i will upgrade from SCADA 2015 to SCADA 2016 and then 2018.
i find it does not integrate easily with Email, but i did find a work around to do what i want. the original project was written in V3.21 on Windows for workgroups and then Win NT (remember that?)
we will be moving to a MES in next 5 years so that's why i think it may be time to go with Ignition.
NT - what a horror! LOL I have used a program with Citect for emails years ago - cannot remember what it was now. I think it was ScadaPhone? Worked OK.
I'm an end-user doing a Sepasoft MES implementation on top of Ignition.
Most of our CompactLogix PLC's only support the one ethernet port. We're using a NAT device to put the PLC on the plant network. We have no issues with this. Ignition isn't hammering the PLC and everything works great.
The only thing with the NAT is that each machine or line or whatever will eat up 2 addresses. You need a public address for the PLC and one for the NAT. In some cases I use the hardware NAT to move to an intermediate address range, and then I use software NAT in the Stratix switch to NAT again up to the plant network. It works fine an and the IT guys don't freak out about using up all the addresses.
I love Ignition and the MES module. We're just getting started, and there is a lot to learn, but the support is fantastic. We're running our line-side andon displays with R-Pi's and they work great. A $50 R-Pi vs. a Win10 box for each installation is going to save a ton of expense.
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
489
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,144
Had a philosophical discussion with a colleague of a related discipline today and I want to get the opinion of the folks here. The most common...
2,593
Hi, I am looking at the setting up some new ethernet comms which is originating from an SLC 5/05 to four new identical CompactLogix L24ER's...
2,539
Hi! When using a PLC and HMI from different brands i have to write up every variable on the HMI end. Whats the best practice on this? Is it a...
1,715
