Best sensor to detect BLACK object
AB2005
Nov 2006
Lahore
320
Hi;
We need to install a sensor to see the running web (sometime brown web sometime white) of a corrugator machine whose max speed is 250M/min. When an A4 sized BLACK paper is detected on that running corrugated web, sensor should give a pulse to system. Goal is to detect the BLACK A4 Paper on running web. The min distance of sensor to web will be 400mm i.e. we can not move the sensor more down. System voltage is 24VDC.
Do you please guide me which kind/brand of sensor is the best to use for such application? The viscosity of ink on said A4 sized black paper is changed i.e. sometime pure black and sometime light.
We have tried regular defuse type sensor but sometime it works sometime not. We need 100% results.
SWAG
I would contact SICK with your application. Is there a UV property to the material? I've used that in the past for detection.
HTH
If no sensor can adequately sense black material I would put a sensor that doesn't respond to black and either a through beam, ultrasonic or sensor/reflector that will detect any material.
If the through beam/reflector/ultrasonic says there is material but the other sensor is Off then it must be black and not visible.
I've also had good luck with a Keyence colors sensor years ago in a food packaging application.
Depending on the sheen of the black material no optical sensor may see it ever. If it is similar to flat or satin paint sheen it would not be seen at all. If it is gloss or semi-gloss then a perpendicular sensor could reflect off the sheen and not necessarily be able to sense the actual color.
Sick do colour sensors that work quite well, used these on detecting a black ink splodge on soap packets for rejects, however, we also had a second sensor to detect the pack as the black mark was the same as no product but this should not apply in your case. To be honest, most sensor manufacturers have colour sensors but these are not cheap, I suggest if you have contacts with reps from sensor suppliers you get them in and do a trial if you can.
We generally use contrast sensors, but if brown AND white are acceptable and black isn't that's going to be tricky.
I might just use a color vision camera instead.
Hey All, I am looking for advice on the best prox sensor or device to use in this application. Customer wants to be able to count potatoes...
5,133
I just realized that the three new horizontal tanks tanks we're installing this weekend will need a CPT and some in order to allow the provided...
4,206
Hello all! Small newbie question on my road to control instrumentation knowledge, if you please. I need to know what temperature sensor/assembly...
5,515
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
518
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
631
