Best Timer Relay for this Application?
alive15
Oct 2015
Montgomery, AL
721
Good morning guys, I'm searching for a Timer relay which accomplishes the "flasher" condition in the photo attached, however, I need the ability to adjust the t-off and t-on timer for R. My control voltage is always on and I don't have ability to turn the "U" off and on, it is unfortunately always "on". So when R is off, I want t-off to be 20 minutes, and when R is on, I need t-on to be 10 seconds. The relay in the picture has the off and on timer the same with no way to adjust either, so I'm searching for a relay that will work for my application.
Thanks,
Edit: All contacts should be rated for at least 240VAC
I have a Siemens S7300,connected to a HMI and want to be able to display and alter a timer value. I have read a couple of suggestions but would...
3,047
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
492
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
608
I am going to need to use HART multi-drop in order to handle a series of Vega Radar units. There are a lot of options and I'm wondering what...
256
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,145
