Best way to convert 12V to 24V
DLMUK
Jun 2013
Southampton
311
Has any body got practical knowledge of using a 12VDC to 24VDC convertor?
A quick Google search produces 100s of options at a variety of prices, can anybody recommend a tried and tested unit?
it will be connected to a 12V SLA battery and need to provide a maximum of 2A output @ 24VDC.
I have used these:
https://www.automationdirect.com/ad...C-to-DC_Converters/Encapsulated/PSE24-DC12-60
No problems. They have a DIN rail mount version too, but if I recall, the encapsulated model was more efficient.
We often use the PULS buffer module when we need 12VDC battery backup for 24VDC power applications, but it is almost $400 and the DC-DC converter is only a part of its functionality. If you are strictly running from battery power and there is already a separate charging system for it, then try the little RHINO converter.
EDIT: fixed my link...it was the wrong output voltage...thanks Jason...
Hi, My boss just ask me to convert all add on instructions into normal rungs. Currently, it is add ons in add ons.......... I am just wondering...
2,569
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
498
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
611
I am going to need to use HART multi-drop in order to handle a series of Vega Radar units. There are a lot of options and I'm wondering what...
260
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,151
