Bit assignments AB ML 1000 TON
There are only three named status bits in an A-B Timer status word.
Bit 13 is Timer Done /DN
Bit 14 is Timer Timing /TT
Bit 15 is Timer Enabled /EN
1747-RM001, page 2-9 is the authoritative reference on the state of each bit at each state of the Timer instruction and in each Controller execution mode (Program, Run, and First Scan).
not sure what you mean by "complete" - but if you really are looking for what goes on "under the hood" of a TON instruction, then the following post might be useful ...
http://www.plctalk.net/qanda/showthread.php?p=6439&postcount=32
if that one post doesn't do it, read the rest of the thread - and then let us know if you're looking for something else ...
how about a specific question? ... if you can tell us what you're trying to accomplish, then I'm pretty sure that we can help with your quest ...
See the screenshot of EIP tag list. We are trying to read in a digital input that is hard-wired. It is shown here as I31.1. I believe we cannot...
285
A couple days ago I accidentally toggled an alwasyoff bit. The issue is it was set up as a single OTU on a rung, nothing else, and used as XICs...
228
Hi I have an old panel builder 32 that I’m replacing for a factory talk me hmi . In the plc for the old panel builder there is a coms bit for the...
76
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
162
I tried researching but I still don't quite get it. As far as I understood, it's used after a function is called in STL and then if the function...
147
