bob_g
I wrote a program for a SLC5/05, downloaded it and it won't set the bit when I'm online with the program. Is there a limit to the addresses that bits can have? Do bit addresses have to be unique, meaning I can't have two coils with the same bit address on different rungs? The logic kinda looks like this:
I:1/1 I:1/2 B3/93
When online with the program I can see that inputs I:1/1 and I:1/2 get "energized" when the input is activated but the coil B3/93 never energizes. I have a couple other rungs below where the coil has the same bit address. Is this the problem? I thought I could do that. I have other bits in the program with higher unique addresses like B3/177, B3/188 and so forth and they work fine. What am I doing wrong? I'm kinda new to all this and any help you could give me would be greatly appreciated.
I:1/1 I:1/2 B3/93
