bit shift contol on 10 station index table
georgia boy
May 2005
hi everyone
i need help with a bit shift application i am setting up on an assembly machine index table . i have a good understanding of the bsl function . but i need ideas on how to control it when the machne stops or faults . startup method and shut down method
if anyone has an idea i could use i would be very grateful
thanks
georgia boy
The normal practice of triggering the rung with the shift instruction is to tie it to any machine movement during index activities with some interlocks to prevent false triggering.
You can include the machine stop or alarm condition in the interlock to prevent it from triggering.
Hi All. I have a very specific question about tracking using an encoder and bitshift register. We would like to use a Compact or Control Logix PLC...
40
1,757
Hello. I've been using the answers in this forum for a while now, so thank you. Usually I can find the answer I'm looking for with a basic...
768
Hi, I need some help write a PLC instruction. I am using Proficy Machine Edition 6.5. Our indexing rotating table has 3 nests that are equally...
4,015
Good morning (EST), I am trying to implement the code below in on an S7-1200. It's barely half a dozen instructions, but I am stuck; I have not...
26
5,701
I have a program I need to work out for a client and I'm having trouble figuring out the correct logic to do it. Let me see if I can explain it...
27
6,569
