Block Measuring
@bernie the beam spacing is 2.5mm split but largest between 2 points is 5.1 if im only looking for 6/35mm i believe this could give us easy solution for tolerance checking. the lasers are great but i have very little window and i am dealing with very pitted pitted cellular concrete not so much a smooth surface. so with the laser woulndt it be possible that it will see this pitting and fail a good block thinking it wasnt in tolerance specs of +\- 1/4in
bringing this topic back up, i caled in and spoke to a bunch of different venders, and based on all the information we are going to buy the laser distance sensors....we have a demo sensor that i have already set up and is reading perfectly! thank you again okiepc for a step in the right path, now a have been programming this for just 2 days, i have most everything set up to a point, than i realized i had forgotten about slanted blocks, also i was to understand the operator for now was going to be telling the machine what size block was going through...i have a PanelView600 hooked up to a SLC 5/03, the way i had it written was the operator was to punch in what size block was comming into the measuring machine, the plc would than input the tolerance specs, and if it met within the range would pass or fail, now they tell me they dont want the operator interface, so i have about 200+ lines of code to be reworked, wanted to see if there was an easier way of doing this,...our blocks range from sizes 4" to 42" and can either be straight or sloped, if sloped the low number comes into the measuring machine first than the high number. im thinking now of useing limit test instruction but how can i achieve this for the slanted blocks? maybe im just thining too deep. any help would be appreciated
Hi all. What is the purpose of that block (MVM) when used with a 2#1111_1111_1111_1111 mask in that situation? I'm really hoping there is...
164
Hi All, I'm just trying to understand the reason behind something I recently experienced. Background: The system contains 4 CompactLogix...
158
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
144
Hello, This product that I have the 1790D-T8BV8B is discontinued, does anyone have the EDS file for it? I wonder if TechConnect will have this...
217
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
143
